Bonding T1's - VWIC-2MFT-T1
Has anyone bonded 2 T1's on one of these WICS's? I assume you would use multlink PPP to do so. I would be bonding both ports in the same VWIC so get a 3MB pipe between 2 locations.
TIA,
Lee
Purple
Re: Bonding T1's - VWIC-2MFT-T1
That is correct, Lee.
Here's a sample config:
Router 1
interface Multilink1
ip address 10.1.1.1 255.255.255.0
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0/0:1
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1:1
no ip address
encapsulation ppp
ppp multilink
Router 2
ip address 10.1.1.2 255.255.255.0
no cdp enable
ppp multilink
no ip address
encapsulation ppp
ppp multilink
interface Serial1/0:1
no ip address
encapsulation ppp
ppp multilink
Hope that helps - pls rate the post if it does.
Paresh
MLPPP and MFR should work the same on these VWICs as they do on the WIC-1DSU-T1V2 et al. I've not run MLPPP on these VWICs, but I have run MFR and it works fine. Since you're using the MFT series of cards I'm assuming that you're doing standard telephony and/or VoIP along the way. If you are going to use MLPPP anywhere in the path of RTP bearer (voice) traffic, make sure that the T1s that you're using have approximately the same delay. Wide variance in delay between the two T1s could cause poor voice quality.
274
