Community Member
Bonding Two T1s with a 3620
I am attempting to bond a couple of T1s into a single pipe for the network. It's supported by the ISP (SpeakEasy), but they won't support a config on a router they don't provide. As far as I know, this SHOULD be working, but can someone else take a look at this and tell me if I'm doing something wrong? I had to adapt the config from one I knew of on an 1841. Here's the current config:
Current configuration : 2405 bytes
version 12.3
service password-encryption
hostname w2mrouter3620
logging buffered 4096 debugging
enable secret 5 $1$Jlqq$70Q8tQy4jh65n1sPd/X7V1
ip subnet-zero
ip cef
no ip domain lookup
ip name-server 64.81.159.2
ip name-server 216.231.41.2
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
controller T1 0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 0/1
shutdown
framing esf
linecode b8zs
controller T1 0/2
framing esf
linecode b8zs
controller T1 0/3
shutdown
framing sf
linecode ami
policy-map fair
class class-default
fair-queue
interface Multilink1
description 572337
ip address x.x.x.x 255.255.255.252
service-policy output fair
load-interval 30
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink links maximum 4
ppp multilink links minimum 1
ppp multilink group 1
interface Ethernet0/0
description Inside LAN
ip address z.z.z.z 255.255.255.224
ip verify unicast reverse-path
full-duplex
no keepalive
interface Serial0/0:1
description 572336
no ip address
encapsulation frame-relay IETF
load-interval 30
frame-relay lmi-type ansi
interface Serial0/0:1.16 point-to-point
frame-relay interface-dlci 16 ppp Virtual-Template1
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial0/2:1
description 572298
no ip address
load-interval 30
interface Serial0/2:1.16 point-to-point
interface Virtual-Template1
description member link of 572337
ppp multilink
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Multilink1
access-list 10 permit 216.254.0.0 0.0.0.255
access-list 10 deny any
banner login ^CC
Unauthorized access prohibited. Web2Market employees only!
^C
line con 0
password 7 111E4B081443180F54
login
line aux 0
line vty 0 4
access-class 10 in
password 7 044C590B0C705F4D59
login
transport input telnet
ntp server y.y.y.y
end
Any ideas? Thanks.
Re: Bonding Two T1s with a 3620
The config looks fine but can you let me know whether it is necessary to run Frame relay encapsulation on your links
Configs would have been easier with a plain PPP encapsulation
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
Narayan
Community Member
Well, it's hard to say conclusively. Like I said, I'm just working off of information the ISP gave me, and they listed in a partial sample config running it with frame-relay encapsulation. Is this something I can change on my end without affecting the other? I mean, is it possible to change it to ppp without having to get buy-in from the ISP?
Hall of Fame Super Gold
Agree with Narayan, but considering that speakasy, as dynamic and nice ISP they are, is still a second tier ISP, so they are based on frame relay for T1-class customers, hence the need for MLPPP over frame relay.
It should work.
230
