Community Member
Booting problem on 3660 Router
I have a 3660 series router that has failed to boot up. I connected with a console cable and discovered that instead of loading the IOS image, the router comes up with unreadable black lines.
Re: Booting problem on 3660 Router
hi
can you try changing the baud rate once its giving the unreadable lines.
most probably u mite have setup different rate in ur console config .
regds
Community Member
Seems like 'console terminal baud rate' problem - by
default it should work at 9600. Please check
the following doc for details/options:
http://www.cisco.com/en/US/products/hw/routers/ps232/products_quick_start_chapter09186a00802ec8f9.html#41122
117
