Webcast-Catalyst9k
Booting problem with c2801
Greetings friend !
I am experiencing a booting problem in our c2801 model. After powering router on, router boots again and again without stopping.
AGAIN AND AGAIN ROUTER IS SHOWING SAME SEQUENCE FOR INFINITE TIME. Pressing break key iam able to jump to rommon, but even though after using ?confreg 0x2102,- 15 not able to configure the router to boot normally.
PLS HELP!
the actual configuration of router is below:
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c2801 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0xd49718
Self decompressing the image : #################################################
######## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X0013 0X00035000 Card in slot 2
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 7692663 bytes to IO Memory.
PMem allocated: 117440512 bytes; IOMem allocated: 16777216 bytes
******C2801: FPGA PCI Base Address Register MISMATCH. Bus 0, Dev 17, Wrote: 0x4 B000000, Read: 0xFFFFE000.
PLD version 0x10
ID MEMORY_REQ TYPE
PLD version 0x10
1 REPLY
Re: Booting problem with c2801
Your router is experiencing a hardware problem that is indicated by the following line:
Best thing will be to open a TAC-case and send it in for repair.
Leo
376
