01-10-2007 06:12 AM - edited 03-03-2019 03:19 PM
I Have Cisco 3750 yesterday it was suddenly down in our Live network ... i dont know wht happen and now when i am going to chk it .. I think It IOS curropted becoz there is messg of IOS cupportion.
i have pasted the Output of Sw, which got from it plz chk and sugest shuld I upload in it new IOS image .. or any other Solutions
Thanks in Advance.
Swwwwwwwwww out PUT
XXX________XXXXX_______XXXXX______XXX
Base ethernet MAC Address: 00:12:80:a9:9d:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 3 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 4055040
flashfs[0]: Bytes available: 11943936
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-i5-mz.121-19.EA1d.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Error loading "flash:c3750-i5-mz.121-19.EA1d.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3750-i5-mz.121-19.EA1d.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
done.
Loading "flash:c3750-i5-mz.121-19.EA1d.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
done.
Error loading "flash:/c3750-i5-mz.121-19.EA1d.bin"
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
01-10-2007 07:35 AM
Hi Afzal,
This link will help you recover your switch from rommon.
http://www.cisco.com/warp/public/473/192.html#subtopic1a
Ankur
*Pls rate helpfull post
01-12-2007 03:52 AM
Thanks for the ANS!!!!
What have happened i want to tell u that I was follwing the steps .. as mentioned in the above DOC. (you have sent me in last post)
I Powered off SW and then agian Poweded ON while pressing the MODE Button.... buy this it boot normally and now its ok...
wht is this i could nt understand last time i have tried to boot severl time but it was not working..
now is fine wht u suggest now ???
Thanks and regards
01-12-2007 04:24 AM
Hi Afzal,
If it had booted fine you can leave it like that but I will like to check the output of
sh boot
sh flash or dir flash:
sh run | in boot
sh version
Ankur
01-12-2007 05:11 AM
Hi Ankur,
Thanks for the reply plz chk the follwing output
Switch-04#sh boot
BOOT path-list : flash:c3750-i5-mz.121-19.EA1d.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Switch-04#sh flash:
Directory of flash:/
2 -rwx 4050902 Mar 01 1993 00:04:52 c3750-i5-mz.121-19.EA1d.bin
3 -rwx 2096 Mar 01 1993 00:02:33 config.text
4 -rwx 5 Mar 01 1993 00:02:33 private-config.text
15998976 bytes total (11943936 bytes free)
Switch-04#sh run | in boot ?
LINE
Switch-04#sh ver
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(19)EA1d, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 05-Apr-04 22:06 by antonino
Image text-base: 0x00003000, data-base: 0x009206D8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE
SOFTWARE (fc1)
Switch-KHI-04 uptime is 4 minutes
System image file is "flash:c3750-i5-mz.121-19.EA1d.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision F0) with 118776K/12288K
bytes of memory.
Processor board ID CAT0749X21W
Last reset from power-on
Bridging software.
1 Virtual Ethernet/IEEE 802.3 interface(s)
24 Gigabit Ethernet/IEEE 802.3 interface(s)
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:12:80:A9:9D:00
Motherboard assembly number : 73-8046-07
Power supply part number : 341-0048-01
Motherboard serial number : CAT08470E6E
Power supply serial number : DTH08441HXN
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750G-24T-E
System serial number : CAT0749X21W
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.1(19)EA1d C3750-I5-M
Configuration register is 0xF
01-12-2007 05:36 AM
Hi Afzal,
Everything looks good to me. Only thing I can presume the problem could be the automatic boot process may not be working for some reason and is the reason after flash got initialized it was not booting up after you pressed the MODE button it interrupts the automatic boot process and after that it may have booted just fine.
Somehow I will recommed it could be issue with the image on the switch. If possible just upgrade the new image and while upgrading overwrite the old image.
Ankur
*Pls rate all helpfull post
