bps(conform rate) in rate-limit is not in exact increments of 8 kbps
Hi all,
I have 1 questions regarding the rate-limit.
According to the cisco documentation, the rate limit command will have the following parameters:-
bps - Average rate, in bits per second (bps). The value must be in increments of 8 kbps. The value is a number from 8000 to 2000000000.
When I execute this command on a interface GigabitEthernet8/1/0.100 of a SPA card,
rate-limit input access-group 114 8000 20000 40000 conform-action transmit exceed-action set-prec-transmit 0
Response:
Adjusting conform rate to match hardware supported rate 64000 bps
Question:
The conform rate is a multiple of 8000. But, when I entered the value 8000 in the command, why is the conform rate getting changed from 8000 to 64000 bps?
Is it because it is a SPA card or Gigabit interface? Is there a way to get this value(64000) from the router using any other command?
Also, there is 6 subinterfaces of GigabitEthernet8/1/0 like GigabitEthernet8/1/0.100, GigabitEthernet8/1/0.200,etc.
Please help.
SPA card Details:-
SLOT 8 (RP/LC 8 ): Modular SPA Interface Card (10G)
MAIN: type 117, 800-26102-02 rev A0
Deviation: 0
HW config: 0x01 SW key: 00-00-00
PCA: 73-9863-03 rev A0 ver 8
Design Release 1.0 S/N SAD093605KC
MBUS: Embedded Agent
Test hist: 0x00 RMA#: 00-00-00 RMA hist: 0x00
DIAG: Test count: 0x00000000 Test results: 0x00000000
FRU: Linecard/Module: 12000-SIP-600=
Processor Memory: MEM-LC5-1024=(Non-Replaceable)
Packet Memory: MEM-LC5-PKT-512=(Non-Replaceable)
L3 Engine: 5 - ISE 10 Gbps
MBUS Agent Software version 2.69 (RAM) (ROM version is 2.65)
ROM Monitor version 1.13
Fabric Downloader version used n/a (ROM version is 4.3)
Primary clock is CSC 1
Board is analyzed
Board State is Line Card Enabled (IOS RUN )
Insertion time: 00:00:04 (6d13h ago)
Processor Memory size: 1073741824 bytes
TX Packet Memory size: 268435456 bytes, Packet Memory pagesize: 32768 bytes
RX Packet Memory size: 268435456 bytes, Packet Memory pagesize: 32768 bytes
0 crashes since restart
SPA Information:
subslot 8/0: SPA-1XTENGE-XFP (0x483), status is ok
subslot 8/1: SPA-1X10GE-L-V2 (0x50C), status is ok
SUBSLOT 8/0 (SPA-1XTENGE-XFP): 1-port 10 Gigabit Ethernet Shared Port Adapter XFP based
Product Identifier (PID) : SPA-1XTENGE-XFP
Version Identifier (VID) : V01
PCB Serial Number : JAB094205E7
Top Assy. Part Number : 68-2430-01
Top Assy. Revision : D0
Hardware Revision : 3.2
CLEI Code : IPUIAKBRAA
Insertion Time : 00:00:13 (6d13h ago)
Operational Status : ok
SUBSLOT 8/1 (SPA-1X10GE-L-V2): 1-port 10 Gigabit Ethernet Shared Port Adapter XFP based
Product Identifier (PID) : SPA-1X10GE-L-V2
Version Identifier (VID) : V02
PCB Serial Number : JAE1143124A
Top Assy. Part Number : 68-2614-02
Top Assy. Revision : A0
Hardware Revision : 1.2
CLEI Code : IPUIA5VRAA
Insertion Time : 00:00:14 (6d13h ago)
1 REPLY
Hall of Fame Super Silver
Re: bps(conform rate) in rate-limit is not in exact increments o
Hello Thilakh,
this kind of limitation is hardware dependent you are using a powerful multilayer switch with a SIP and SPA combination.
a limitation of 64 kbps should be acceptable given the high speed links expected on this platform
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/76cfgeth.html
Hope to help
Giuseppe
610
