Community Member
Break traceroute
How to break a traceroute, I tried CTRL-shift-6-X didn't work. Thanks in advance.
Yavuz
Re: Break traceroute
Hi Yavuz,
Can you just try CRTL-shift-6 and update if it works?
Ankur
Hall of Fame Super Gold
In my experience you usually have to hit the key stroke combination several times. But I have found CTRL-shift-6 to be effective in breaking a traceroute on a Cisco router.
Rick
5032
