Community Member
Bridge IRB and router administration - 1603 router
We need to make a couple of changes to our configuration and would appreciate any feedback on possible pitfalls.
The configuration is as follows:
2 x Cisco 1603 Routers on ethernet LANs linked via leased line.
Router 1 -
configured for Bridge IRB
Ethernet + Serial + BVI all in bridge-group 1
Ethernet - no IP address
BVI - 192.168.0.y
Admin only via console port or ISDN BRI0 incoming.
Router 2 -
Ethernet + Serial in bridge-group 1
Ethernet - 192.168.0.x
Admin via ethernet IP address
We need to achieve the following:
1. Change the IP addresses - that's OK but how is the BVI IP address actually used and what are the implications of changing it ?
2. Get admin via the local ethernet for router 1 if possible - will assigning an IP address interfere with the bridge operation.
Many thanks
Hall of Fame Super Silver
Re: Bridge IRB and router administration - 1603 router
Hello Philip,
for R1 you should be able to access it via telnet using the BVI ip address
verify that:
there are the commands
bridge 1 bridge ip
bridge 1 route ip
and a default route pointing to 192.168.0.x
only doubt :
192.168.0.x should be associated to BV1 on R2 too otherwise how could the two ip addresses have a direct communication ?
I think this is your issue
eth1 on R2 should be in a different subnet and all should be fine
Hope to help
Giuseppe
Community Member
Hi Guiseppe,
Thank you for the response.
R1 doesn't respond to telnet on the BVI IP.
It's missing the Bridge 1 bridge ip command.
Also I can't see any reference to a default route on either router.
In addition, we would like both ends to be on the same subnet ?
If we configure both routers with the same BVI IP, how could I telnet onto one via that IP ?
I'm wondering if this is just completely mi-configured but lucky it's working.
Would you consider glancing at the IOS commands if I post them ? I understand if you don't have time.
Thanks again
Hello Philip,
the two routers must share a common IP subnet.
R1:Bvi1 and R2:bvi1 need to be in the same subnet but to be different
example
R1:Bvi1 192.168.0.1/24
R2:Bvi2 192.168.0.2/24
if you want you can make also R2:eth1 part of same bridge-group 1 to support a flat network (using a single IP subnet)
to be able to telnet you need also to set a password under line vty
line vty 0 4
login
password thisisapass
when you can ping R1:BVI1 from R2 you should be fine.
the default route is needed to reach other subnets if there is only a subnet you don't need it.
If needed R1 can point to R2:Bvi1 and R2 to some other router to reach other IP subnets
Hope to help
Giuseppe
222
