Bridge Mode
I'm currently after buying a Cisco 857 and putting it in bridge mode.
Does anyone have a basic config of how this would work.
I'm guessing the ppp authentication can still take place in bridge mode?
I want to plug a cisco ASA into it to terminate all the VPN'S and do the natting.
  • WAN Routing and Switching
Bridge Mode
Hi, you want to terminate the dsl line in the router and to the pppoe on the firewall
on the atm bridge-group 1 (plus the pvc commands), on the vlan 1, bridge-group 1 and on global config bridge 1 protocol ieee
Kind regards
Bridge Mode
I'm currently testing on a cisco 837 here is my ADSL config without bridge mode. Yes i want the DSL to terminate on the router as shown below with dialer0 doing authentication. then would like to plug my ASA into the ethernet port with a public IP. obiously i will get rid of nat and the local IP. can you confirm the rest of the config i will need ?
interface Ethernet0
ip address 192.168.90.254 255.255.255.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
hold-queue 100 out
interface ATM0
ip address dhcp
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname *****
ppp chap password 0 ****
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
Bridge Mode
also i have been reading it is pvc 8/35 not 0/38 is this correct and encapsulation aal5snap ??
Bridge Mode
Hi, this config is in routed mode. do you want the ASA to get the public IP address, then remove all pppoe commands and the dialer0 interface and bridge the wan and the E0 interfaces
interface Ethernet0 ! in case of 857 interface will be vlan 1
bridge group 1
interface ATM0
!ip address dhcp is wrong, it gets address with IPCP but if you want a bridge you don't need any ip address in here at all
bridge group 1
pvc 8/35
interface loopback 1
ip address 1.1.1.1 255.255.255.255
!this is just for management
and then the ASA must do the PPPoE authentication and the NAT. Cisco router will be like a modem with the management ip address 1.1.1.1
Kind regards
Bridge Mode
Having a few issues here is my config below on the router.
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
bridge irb
interface Loopback1
interface Ethernet0
no ip address
bridge-group1
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
pvc 8/35
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
On my ASA which is configured into ethernet0 i have done some debugging and get the following.
ciscoasa(config)# PPPoE: send_padi:(Snd) Dest:ffff.ffff.ffff Src:7cad.746f.8bef
PPPoE: Ver:1 Type:1 Code:09=PADI Sess:0 Len:12
PPPoE: Type:0101:SVCNAME-Service Name Len:0
PPPoE: Type:0103:HOSTUNIQ-Host Unique Tag Len:4
PPPoE: 00000004
PPPoE: padi timer expired
Any idea what the above means?
Bridge Mode
hi, you need bridge 1 protocol ieee and you don't need ip routing so apply no ip routing  the rest of your config looks fine
check if the interfaces are bridging
R2#sh bridge 1
Total of 300 station blocks, 298 free
Codes: P - permanent, S - self
Bridge Group 1:
    Address       Action   Interface       Age   RX count   TX count
c200.1244.0000   forward   FastEthernet0/1   2          5          4
c202.1244.0001   forward   FastEthernet0/0   2          5          5
you should see your vlan 1 and the atm0
and remove the loopback ip and give it to the interface bvi1
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a78c.shtml
kind regards
Bridge Mode
Thanks for the reply. I will check this out and let you know how i get on. It will be monday now.
Thanks again.
Bridge Mode
Done the above and see this on the router.
Bridge Group 1:
7cad.746f.8bf2   forward   Ethernet0         0          9          0
Router#
Outside interface on ASA is set to PPOE with the correct username and password. Debug ppoe shows
padi timer expired. Do a debug ppp authentication shows nothing so i'm guessing it's not even hitting the ISP. problem could be on the bridged router.
Bridge Mode
Should i not see the atm0 interface when i do show bridge 1 ?
328
