broadcast traffic
Is the "broadcast traffic" 255.255.255.255?
If so, can VLAN block it?
rdgs
1 ACCEPTED SOLUTION
Re: broadcast traffic
As a frame comes through an ingress port, the switch does three things ... 1. where to forward it, 2. should it be forwarded, and 3. how it should be forwarded.
#2 is refering to QoS and those types of things so we are really talking about #1 and #3.
1. The switch takes the frame's destination address and looks it up in the Content Addressable Memory (CAM) table. If the address is there, all it has to do is read off the egress port and the vlan ID to figure out which port it needs to go out (that is #3). But if it can't find the address (and this is what we are interested in), the switch will then flood that frame out every switchport ... in that vlan.
So ... a switch will not forward a broadcast out every switchport ... just every switchport in a vlan. A frame containing the address FF:FF:FF:FF:FF:FF will be forwarded to all connected segments ... of that vlan.
I think the broadcast address depends on the subnetwork address. For instance ... 10.0.0.1 /8 has a broadcast address of 10.255.255.255.
VLANs are broadcast domains so switches will forward all broadcast but a router (or switch running router process) will not. So, essentially, I think the answer to your question is yes. A router will not forward any broadcast from one network segment, or vlan, to another.
Maybe one of the experts can verify.
hth,
Richard
Hi Richard,
If the broadcast address is 10.255.255.255 and there are two VLANs in the same switch, then the 10.255.255.255 broadcast traffic should be within the same VLAN switch ports. It will not flood to another VLAN.
If the broadcast address is 255.255.255.255 and there are two VLANs in the same switch, then (I guess), the broadcat traffic "may" flood to another VLAN. I am not sure.
If so, it may have one issue. if one PC has a lot of broadcast traffic (255.255.255.255) on the segment, it is not only affect itself VLAN, but also to affect another VLAN which is in the same hardware.
how to address or work around to solve it?
rdgs
A switch is unable to dissemenate traffic across vlans. It has to send traffic up to the router for that to happen. That is how they got the name router on a stick. Routers do not forward broadcasts ... they discard them. So a broadcast in one vlan will not propogate into any other vlans.
Hi Richard,
if the broadcast MAC address is ff:ff:ff:ff:ff:ff, does it flood (or forward) the frame to all ports of switch?
rdgs
You cannot block a broadcast traffic within the same VLAN.
Broadcast traffic can be blocked thought for each different VLAN.
This is to say that:
WITHIN VLAN: broadcast not blocked.
INTER-VLAN: broadcast blocked.
Hope this helps.
k0rg
482
