Community Member
BT Broadband PPoA Issue
We have a cisco 1841 with a wic-1adsl card installed.
We are connecting this to BT Broadband in belfast and was told it was PPoA we got the username,passwords and also told that the static ip address has a mask of
When connecting the dsl port to the adsl wic we get a physical port in the atm module as initialising then down and under the debugs we get the following.
*Sep 11 13:21:03.831: DSL: Received response: 0x22
*Sep 11 13:21:03.831: DSL: Open failed: Handshake or init message invalid or had bad CRC -- retrying
We have the following config.
interface FastEthernet0/0
ip address zzzzzzz
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface ATM0/1/0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
dsl enable-training-log
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 0 yyyyyy
ppp pap sent-username password 0 yyyyy
ppp ipcp dns request
ppp ipcp wins request
ip classless
ip route Dialer1
ip route 200.x.x.0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
dialer-list 1 protocol ip permit
Community Member
Re: BT Broadband PPoA Issue
Can u plz send me the result of <>
Community Member
Thanks for the mail.
See below.
Portadown#show ip int brief
FastEthernet0/0 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/1/0 unassigned YES NVRAM initializing down
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Dialer1 unassigned YES NVRAM up up
ATM0/1/0 is down, line protocol is down
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 800 Kbit, DLY 640 usec,
reliability 0/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output never, output hang never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
Also, If you plug a netopia router into this it works.
Community Member
What IOS version are you using?
I am fairly sure I have seen this before and it needed the very latest IOS to work.
Don't ask what the very latest version at that time was :-)
