Bug ID CSCti63508
Just wondering if anyone has ever come across this bug.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti63508&from=summary
I've just installed a 2951 into a site and I need to set up multiple site to site vpn's,  i have all teh VPN's configured, with the crypto ACL's all containing object groups.
When I apply the crypto map to the interface, I loose connectivity to the outside world.  I can't ping my next hop, I can't get into the router from the outside etc,  When I remove the crypto map, everything comes back to life.
I'm having trouble deciphering the "conditions" under which this bug applies, maybe someone has come across it.
While I'm here, what's the story with upgrading version 15.1 IOS versions.  Can I still upgrade the minor version without violating the license like the older IOS versions.?
Neil
Re: Bug ID CSCti63508
OK - so is this right.....???
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_object_group_acl.html#wp1132617
- Object Groups are not supported with IPSec.  Is that why they won't work with my crypto maps.............
Needless to say - I'm not happy.......
Hi Neil,
Yes, that's correct, you can't do that, it's currently unsupported.
I suggest you contact your account team with your request. Maybe it will be implemented one day by this bug:
CSCsq33560    ENH: Add support for object group ACL in ipsec crypto ACL.
It's not easy to implement because of crypto hw limitations, e.g. on VSA.
Developers are currently not working on it because they haven't seen enough interest from customers.
The bug you mentioned is only related to ACLs, not Crypto. You can ignore it.
cheers,
Xavier
218
