Webcast-Catalyst9k
Building redundancy/load balancing in WAN setup
We are trying to achieve HA (Device & link redundancy) & load balancing in our existing network. Please refer to the attached PPT for a detailed description of our migration plan.
Existing
3825 Data Router
3825 Voice Router
3650 Inside Switch
2960S DMZ Switch
Planned
3925 Data/Voice Router  x 2 (Active/Active)
3750-X Inside Switch  x 2
3750-X DMZ switch  x 2
Data   Router Services :-  ( Cisco   3825)
1)   OSPF Routing for Interfacility connectivity
2)   Policy Based Routing
3)   QOS ( VLAN Based Police) ( IN / OUT)    on LAN and WAN links
4)   GRE Tunnels
5)   Static Route
6)   AAA Service
7)   Syslog
8)   SNMP
9) Netflow   Service
10)   NTP service
11)   Ethernet Lease line ( Via Inside Switch using Sub-Interface)
Voice   Router Service Running :- ( Cisco 3825)
1)   PRI Configuration
2)   FAX/ FXS
3)   SRST Configuration
4)   DHCP  for VoIP
       5) DISA Service
Inside   Switch Service Running :- ( Cisco 3560)
1)  Ethernet Lease line ( Via Router using   Sub-Interface)
          ( Layer   2 Vlan)
2)   Normal Firewall Connectivity  in   Default VLAN
DMZ   Switch Service   Running :- ( Cisco 2960S)
1)   Layer 2 Vlan
  • What is the simplest way to achieve this setup?
  • Is Active/Active mode possible on the routers keeping in mind the services we are running?
  • I have attached the current configs. If someone can post a sample config that would be great.
228
