Community Member
Bundling T1s with Multilink PPP
I have two remote offices that connect back to me through two P2P T1 lines (for a total of 3Mb). Currently the load balancing is done through ip load-sharing per-packet but we are looking into video conferencing so I can't use that anymore.
I want to configure multilink interfaces and bundle the serial ports and I have a question about the config on the hub router. I have configured a multilink interface before but I have never done two on the same router. Would this be the correct config?
conf t
interface multilink1
ip address x.x.x.x y.y.y.y
encapsulation ppp
ppp multilink
ppp multilink group 1
interface serial0/0/0:0
encapsulation ppp
ppp multilink
interface serial0/0/1:0
encapsulation ppp
ppp multilink
interface multilink2
encapsulation ppp
ppp multilink
ppp multilink group 2
interface serial0/1/0:0
encapsulation ppp
ppp multilink
interface serial0/1/1:0
encapsulation ppp
ppp multilink
1 ACCEPTED SOLUTION
Re: Bundling T1s with Multilink PPP
The interface number is what your referencing the serial interface to. Mutlilink 1 or Mutlilink 2
Does my explanation make sense?
**Update: Sorry, I just double-checked and you do need it. Sorry for the mess up. Your config looks just fine.
Under the multilink interface you don't need ppp multilink group 1, but other than that, it looks good.
Hope that helps.
Community Member
Can you clarify that a bit? I thought the purpose of the 'ppp multilink group 1' statement was to define which multilink interface the multilink to which the group was tied. If I don't have that statement on those interfaces then why would I need it on the serial interfaces?
Bronze
I believe you will need multilink group x to associate with each link
231
