08-24-2012 10:51 AM - edited 03-04-2019 05:22 PM
i've some problems using PBR on BVI. In my lab (layout attached) on RTR3 i've configured:
- BVI with two subinterface (f0/0.10 abd fa0/1.10) with one public IP (BVI10: 1.1.1.4/24) to reach ISP1 router (RTR1)
- int fa0/0.255 subinterface to connect the ISP2 router (RTR2)
Attached to RTR3 f0/1 i've connected an ASA on e0/0 (trunk port) with VLAN10 with public IP 1.1.1.5/24, the e0/5 with VLAN1 connects LAN subnet 192.168.0.0 where i've all my hosts.
The ASA's gw is the BVI 10 on RTR3 and RTR3 points to RTR1 with a static route. In this configuration all it's ok and i'm able to reach internet through RTR1.
Now, i would like to apply PBR on RTR3 to redirect http traffic (for example) to RTR2
i'm trying with:
ip access-list extended al-http-traffic
permit tcp any any eq www
route-map RM_PBR permit 20
match ip address al-http-traffic
set ip next-hop 192.168.1.10
and i've:
#sh route-map
route-map RM_PBR, permit, sequence 20
Match clauses:
ip address (access-lists): al-http-traffic
Set clauses:
Policy routing matches: 8711 packets, 605190 bytes
But i'm not able to reach internet..
I think I am missing something... what could be wrong/missing ?
Thank you!
N.
08-28-2012 12:27 AM
anyone has ideas about my question ?
thanks,
N
03-04-2014 06:38 AM
i have the same issue , did you find a solution ?
01-13-2018 09:15 PM
You have to apply to both sub-interfaces f0/0.10 and fa0/1.10 like so:
int f0/0.10
encapsulation dot1q 10
ip policy route-map RM_PBR
end
int f0/1.10
end
01-14-2018 06:17 AM - edited 01-14-2018 06:21 AM
Hello
I must be missing something here so apologies, but why are you bridging on the rtr for the two lan subnets - Looking at your topology a simple "router on a stick" setup would be applicable?
res
Paul
