Bypass GLBP?
Hi all,
Let's say I have two routers (RouterA will be .5 and RouterB will be .6) with a virtual GLBP address of .1
Is it possible to have some hosts on that subnet bypass the GLBP protocol by setting their default gateway to the .5 or 6. address?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Bypass GLBP?
GLBP will come into action only when hosts send data on their default gateway set to glbp virtual ip.
If you bypass the virtual IP then the only the concerned router will reply to the requests and data will flow through it.
Bypass GLBP?
you need to provide def. GW as .1 to your host machines.
you can not bypass glbp for some users.
your inside traffic is load balanced between physical servers .5 and .6 while going out side.
Re: Bypass GLBP?
Bypass GLBP?
Thanks all!
Super Bronze
Bypass GLBP?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
They sure can.  They will also obtain the real MACs and not the GLBP's virtual MAC.
339
