Webcast-Catalyst9k
c1417 CPE, NAT and routable IPs
this may have been answered before, but I am wondering how to have some (10.x.x.x) addresses translated by NAT, while allowing other (63.x.x.x) addresses to be passed through the router.
Basically I'm looking to replace a cisco 678, a DSL router, a Linux box running IPTables, and a VPN Endpoint with a Cisco 1417 I was given. I know the VPN endpoint replacement isn't possible, so how can I route it's public ip (.229) through, while still translating the 10 series addresses. I have a 2924 behind the boxes currently, so I can vlan off the public traffic from the private traffic. A web search came up with partial configs, but nothing definitive. Any Ideas?
1 ACCEPTED SOLUTION
Purple
Re: c1417 CPE, NAT and routable IPs
Howdy,
When you configure dynamic NAT, you typically specify the source addresses that you want NAT'ed via an ACL. In order to translate just the 10.x.x.x addresses, use something like the following:
ip nat inside source list 10 pool NATPOOL1 overload
access-list 10 permit 10.0.0.0 0.255.255.255
I presume you are familiar with the rest of the NAT config. If not, let us know...
Hope that helps - pls rate the post if it does.
Paresh
You can use dynamic nat overload for the 10.x.x.x space - called PAT over a single public ip address. While you can use a static nat between .229 and the private ip address of the VPN box.
i. Lets assume 10.x.x.x is the private space for inside lan.
ii. Let this be Pat'ed to say 63.x.x.230 or even a pool of addresses (say)
To perform i and ii, you need following commands.
ip nat inside source list 10 interface ethernet0 overload
access-list 10 deny host 10.x.x.10
ACL 10 will make sure that traffic from VPN box is not dynamically NATed using above commands.
Interface ethernet 0 is the public facing ethernet interface which has the 63.x.x.230 address configured.
iii. To pass VPN traffic through static nat from 63.x.x.229 to 10.x.x.229 (say). 10.x.x.229 is the ip address configured on the VPN box.
The command required to perform iii is,
ip nat inside source static 10.x.x.229 63.x.x.229
PS: Please remember to rate helpful replies!
Btw I am not familiar with the 1417 CLI. Hopefully it runs IOS and you will be able to set this up via CLI.
P
Purple
Howdy,
Paresh
Will I need to use a 10.x.x.x address on the VPN box, or can it use it's real IP? the reason I'm asking is the VPN box is connected to the 10.x network on the internal ethernet side.
Purple
YOu can use its real IP.. that was the point of only NAT'ing the 10.x.x.x addresses.
How is the VPN endpoint connected to the router ?
Paresh
Current configuration is:
Internet -->cisco 678 ---> 10mbit hub --> (three NAT boxes on three static IPs one for web browsing, one for services (http,mail,telnet), one for vpn endpoint). not Pretty, but it works. :)
Purple
Yep, with what you are proposing (and the ACL I posted earlier) you should be able to keep the public IP on your VPN endpoint...
Paresh
264
