Webcast-Catalyst9k
C2921-VSEC/K9 - Can't configre crypto.....
Hi we have a 2921-VSEC/K9 running c2900-universalk9-mz.SPA.151-4.M4.bin
I can't configure any crypto settings.
"show licence feature" reveals:-
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
gatekeeper               yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
cme-srst                 yes          yes         no             no       yes
WAAS_Express             yes          yes         no             no       yes
UCVideo                  yes          yes         no             no       yes
Do I need to 'activate' the securityk9 feature? If so, how please?
Many thanks in advance,
Matt.
VIP Purple
Re: C2921-VSEC/K9 - Can't configre crypto.....
Hi ,
The IP Base License wont have most of the Advanced Security Features Like Below:
a) IPSec VPNs.
b) DMVPN.
C) Remote Access VPN.
d) Zone Based Firewalling
And Others.
If You require Security Features, You Should Choose the Security License Software.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9001369
The instructions are at
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1097551
For example, if you put the license file on to a USB stick, the command will be along the lines of:
license install usbflash1:license-file-name.xml
Thank you for the response Sandeep. I was under the impression that because the part number ordered was
2921-VSEC/K9, we should have the security licence pre-installed. This does not appear to be the case so my question is around activating a licence that I think we have purchased but does not appear to be activated?
Matt.
VIP Purple
as per your output from sh lic feature:
it shows that its not enabled:
Enable or activate :
or
http://www.rracuares.com/2010/07/31/activating-cisco-isr-g2-evaluation-license/
Can you paste the output of this command: sh ver , sh flash
Lets see VPN module is there or not ?
Reagrds
147
