C3560E-12D and X2-10GB-T does not work
Hello I have problem similar to this one https://supportforums.cisco.com/thread/2014060
Detail: I have WS-C3560E-12D & try to install Xetnpack to BASE-T X2-10GB-T. In the port status I see err-disabled.
I try to c3560e-universalk9-mz.150-2.SE4 & c3560e-universalk9-mz.122-58.SE2 but no luck.
X2-10GB-T installed in the 0/10, I'm attached output from:  sh idprom interface te 0/10
This Xenpack works just fine in the Catalyst 4506 with SUP WS-X4516-10GE. Sup running at cat4500-entservicesk9-mz.150-2.SG7.bin.
Can some one help me?
Re: C3560E-12D and X2-10GB-T does not work
Hi Alex
did you ever got the answer to this ? /got resolved ?
I am having problem getting  X2-10GB-T to work on the same SW WS-C3560E-12DS
Mar 30 01:30:13.675: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te0/1, putting Te0/1 in err-disable state
Mar 30 01:30:16.259: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te0/2, putting Te0/2 in err-disable state
Switch#show inventory
NAME: "TenGigabitEthernet0/1", DESCR: "unknown"
PID: X2-10GB-T         , VID: V01  , SN: DTY16030001
NAME: "TenGigabitEthernet0/2", DESCR: "unknown"
PID: X2-10GB-T         , VID: V01  , SN: DTY155200AU
Even upgraded to latest 15.0
Switch#show ver
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 15.0(2)SE5, RELEASE SOFTWARE (fc1)
NO LUCK
I ask my friend, he talk to TAC about this issue:
1) While  WS-C3560E-12D  End-of-Sale - cisco will not add new features to this device.
2) According to the table presented at http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html#wp48759, switch support only following  10 gig modules:
X2-10GB-LR
X2-10GB-ER
X2-10GB-LX4
X2-10GB-SR
X2-10GB-CX4
X2-10GB-LRM
X2-10GB-ZR
DWDM X2
It is very sad for me, I think it is not so difficult to recompile IOS to add support to X2-10GB-T module.
IOS recompile is not an
IOS recompile is not an obligation in your case : You can go "out of maintenance" with a recent IOS version. I use c3560e-ipbasek9-mz.150-2.SE6 and ask :
(config)# service unsupported-transceive
(config)# no errdisable detect cause gbic-invalid
To get my 3560E working with X2-10GB-T.
Oups, my answer on thread
Oups, my answer on thread bottom...
332
