C3825 IOS info for CCM
HoustonG33K
Hey guys, I have a 3825 router as a gateway for a ccm4.1. I just realized the router is at 12.4 3g. Does anyone have any advice on the newest release I should go? The gateway has 3 PRI's.
Thanks in adavance.
Donnie
paolo bevilacqua
Hi, what you have is fine, 3j is out but unless you run into any bug, I would not change.
There there are the T and other releases that you probably don't need.
ok thanks. The problem I am having is that the ccm-manager config will not download.
Im getting these errors-
*Feb 12 17:47:35.872: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
*Feb 12 17:47:56.884: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
*Feb 12 17:48:17.240: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/uei_4848_mpls_3825-confg) fail
*Feb 12 17:48:38.248: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/uei_4848.cfg) failed
I fixed it, the sybscriber tftp server needed resetting.
