C7200 Subinterfaces Flap
Kindly Advice
The below is one of our PE logs, the problem (as shown in log) the router sub interfaces is daily flaps
Mar 8 11:12:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.122, changed state to up
Mar 8 11:12:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.122, changed state to down
Mar 8 11:12:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.122, changed state to up
Mar 8 11:12:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.367, changed state to down
Mar 8 11:13:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.122, changed state to down
Mar 8 11:14:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.367, changed state to up
Mar 8 11:15:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.344, changed state to down
Mar 8 11:15:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.543, changed state to down
Mar 8 11:16:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.428, changed state to down
Mar 8 11:16:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.543, changed state to up
Mar 8 11:16:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.344, changed state to up
Mar 8 11:17:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.543, changed state to down
Mar 8 11:17:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.126, changed state to down
Mar 8 11:17:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.428, changed state to up
Mar 8 11:18:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.126, changed state to up
Mar 8 11:18:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.214, changed state to down
Mar 8 11:19:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.543, changed state to up
Mar 8 11:19:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.228, changed state to down
Mar 8 11:20:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.228, changed state to up
Mar 8 11:20:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.367, changed state to down
Mar 8 11:21:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.86, changed state to down
Mar 8 11:21:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.367, changed state to up
Mar 8 11:22:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM1/0.367, changed state to down
Re: C7200 Subinterfaces Flap
PE#sh ver
IOS (tm) 7200 Software (C7200-JS-M), Version 12.2(27), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 02-Nov-04 19:40 by X
Image text-base: 0x60008940, data-base: 0x6168E000
ROM: System Bootstrap, Version 12.1(20000824:081033) [dbeazley-cosmos_e_LATEST 101], DEVELOPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.2(27), RELEASE SOFTWARE (fc3)
LNS uptime is 48 weeks, 5 days, 3 hours, 4 minutes
System restarted at 08:14:49 eet Fri Apr 1 2005
System image file is "disk0:c7200-js-mz.122-27.bin"
cisco 7204VXR (NPE300) processor (revision D) with 122880K/40960K bytes of memory.
Processor board ID 23654135
R7000 CPU at 262Mhz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 Cache
4 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 500 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 200 bandwidth points
Please refer to the following document "Cisco 7200 Series Port
Adaptor Hardware Configuration Guidelines" on CCO ,
for c7200 bandwidth points oversubscription/usage guidelines.
Bronze
What is the output of Show interface on the affected port?
Arvind
I solved the problem the router is connected to BPX through STM1 cabel and the port which the cabel connect on the BPX is overutilized load 134%
Bronze
Dint know overutilization could cause line protocol errors mate. Thanks !
Arvind
161
