C7206 VXR with NPE300
Hi Guys,
I'm upgrading this chassis with a NPE400. I have read some documents which state a upgrade of the bootflash is required when I insert this new card.
Am I right in assuming just installing the NPE card wont effect the config or IOS but may require a bootflash upgrade?
My current bootflash version is
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(10)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Thanks guys! We hope this is just a case of powering down, putting the new NPE in and powering back up again!
Thanks!
Re: C7206 VXR with NPE300
Below is my PE router 7206 VXR NPE400:
PE101>sh ver
Cisco IOS Software, 7200 Software (C7200-JS-M), Version 12.4(5), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 31-Oct-05 23:00 by alnguyen
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
PE101 uptime is 3 weeks, 5 days, 15 hours, 22 minutes
System restarted at 04:18:32 MYT Sun Feb 26 2006
System image file is "disk0:c7200-js-mz.124-5.bin"
Cisco 7206VXR (NPE400) processor (revision B) with 491520K/32768K bytes of memory.
Processor board ID 33458293
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
6 slot VXR midplane, Version 2.9
I'm not really sure how that helps me? Can someone tell me where I can download the bootloader files to update the IO card?
Thanks Peter, I read the link earlier and ensured ive got a compatible IOS but it still brings up the error
Router#show bootflash
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image 4224168C 2AB370 25 2536176 Mar 01 1993 01:36:48 +00:00 c7200-boot-mz.120-28d.bin
871568 bytes available (2536304 bytes used)
Router#
Router#sh ver
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.3(11)T3, RELEASE SOFTWARE (fc4)
Compiled Tue 25-Jan-05 22:50 by pwade
Router uptime is 27 minutes
System returned to ROM by reload at 02:30:03 UTC Mon Mar 1 1993
System image file is "disk0:c7200-is-mz.123-11.T3.bin"
Last reload reason: Reload command
Cisco 7206VXR (NPE400) processor (revision A) with 491520K/65535K bytes of memory.
Processor board ID 21272859
6 slot VXR midplane, Version 2.0
294
