C880DATA-UNIVERSALK9-M 3G router problem
khaled alodat
Can some one help me please :
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = CHAP
Username: web, Password: web
Show run :
Current configuration : 1896 bytes
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip cef
no ipv6 cef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
chat-script gsm1 "" "ATDT*98*1#" TIMEOUT 30 CONNECT
license udi pid CISCO887GW-GN-E-K9 sn FCZ1515C2MY
controller Cellular 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer string gsm1
ppp chap hostname web
ppp chap password 0 web
interface Vlan1
ip address 172.16.167.1 255.255.255.0
ip access-group 100 out
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map TEST interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
logging esm config
access-list 100 permit ip any any
route-map TEST permit 1
match ip address 100
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line 3
exec-timeout 0 0
script dialer gsm1
modem InOut
no exec
transport input all
speed 237000
line vty 0 4
login
transport input all
end
Router#sh cellular  0 all
Hardware Information
Modem Firmware Version = K2_0_7_35AP C:/WS/F
Modem Firmware built = 03/04/10
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 234159095528581
International Mobile Equipment Identity (IMEI) = 353223046042389
Integrated Circuit Card ID (ICCID) = 89441000301617276300
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = C9E353012641006
Modem Status = Online
Current Modem Temperature = 28 deg C, State = Normal
PRI SKU ID = 9993559, SKU Rev. = 1.2
Profile Information
PDP Type = IPv4
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = EDGE (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = GBR, Network = voda UK
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 15
Location Area Code (LAC) = 107
Routing Area Code (RAC) = 1
Cell ID = 24945
Primary Scrambling Code = 0
PLMN Selection = Automatic
Registered PLMN = vodafone UK , Abbreviated = voda UK
Service Provider =
Radio Information
Radio power mode = ON
Current Band = GSM 900, Channel Number = 63
Current RSSI = -68 dBm
Band Selected = GSM all band
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
hesham_hitch
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool1
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
license udi pid CISCO888G-K9 sn FCZ1537C0QH
username hesham privilege 15 secret 5 $1$aa7I$vRMM5kBTMKNKTIJssJbJa0
controller DSL 0
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface Cellular0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 encapsulation ppp
 async mode interactive
 ppp chap hostname internet
 ppp chap password 7 020F0A4F0E14012458
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
 ip address 10.10.10.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip tcp adjust-mss 1452
interface Vlan2
 no ip address
interface Dialer0
 no ip address
 no cdp enable
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
logging esm config
logging trap debugging
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
 Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
 login local
 no modem enable
 transport output telnet
line aux 0
 login local
line 3
 no exec
 rxspeed 7200000
 txspeed 5760000
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
scheduler allocate 4000 1000
scheduler interval 500
end
