Cable for PA-MC-8TE1+= port adapter
Hi Sir,
For PA-MC-8TE1+= port adapter, can anyone confirm the correct cable is CAB-E1-RJ45BNC= (description: E1 Cable RJ45 to dual BNC (unbalanced), Spare)?
Thank you.
B.Rgds,
Lim TS
Hall of Fame Super Gold
Re: Cable for PA-MC-8TE1+= port adapter
If you are going to a 75 Ohm circuit using BNC, yes.
The PA-MC-8TE1+ port adapter uses shielded twisted-pair cables with RJ-48C connectors to connect to a PBX or to the Public Switched Telephone Network (PSTN).
Refer to http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/8-port_multichannel_t1.ei_8pri_install_config/2738ins.html#wp1031384
Dandy
219
