Cable HWIC Support
I have just bought a 2811 Router. The current IOS is 12.4(13r). I am trying to get 2 HWIC-Cable-D-2 cards installed. The cards say they are not supported. I am guessing that I need to upgrade to 12.4(14)T to fix this. Is this correct? If so where would I find the IOS?
Re: Cable HWIC Support
Hi Pat,
That should be 12.4(11)T. please check this link out!
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_6xe/snwshoe1.html#wp2121009
Thot
Your right, But 12.4(14)T should have every thing that is in 12.4(11)T right?
yes! That should fix something in 12.4(11)T. May introduce something new as well.;-)
Thot
114
