Community Member
cable issue
I find that the length between far end LAN port to the core switch is over 100M. Can I use Cat 6 cable to overcome this issue? if not, any work around? e.g. put two or more switches in between?
BTW, the 100M limitation is end-to-end (from end user LAN port to the server). Is it correct?
rdgs
Hall of Fame Super Gold
Re: cable issue
How much over 100m? If not much, chances are will work anyway. But it would not a professional and certifiable installation.
So to play it safe, you will need to install a switch in between.
Community Member
Re: cable issue
the lenght of LAN cable should not be over 100M. does it meansure from end to end? (from work station to server). I have some confuse the 100M. what is the definition?
The total is 223M from PC to the server, 135M from PC to switch.
rdgs
Re: cable issue
135m is too much. You need to place a switch in between.
Community Member
Re: cable issue
could you give me a link regarding the LAN 100M limitation?
rdgs
Re: cable issue
Blue
Re: cable issue
Mike:
Thats a great link, dude. I saved it in my favorites.
Victor
122
