%CABLE_MODEM_HWIC-3-CONTROL_PLANE_FAIL: RBCP failure : Adding service flow ACE failed - Ethernet type not supported
I'm having the same issue as this guy: https://supportforums.cisco.com/message/2017814#2017814
but the responses in that thread are not enough to fix the problem- or even get through tier 2 support at the ISP.
This happens every few hours. It requires a cold reload of the router to repair- there might be another way to updown the interface only that works but not one that I'm aware of. I know this is a strange issue but any answers or ideas on how to diagnose would be great as it is a huge detriment to services. It would be nice if we had more than one choice of cable internet provider in this area.
Here is the sh ver:
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(6)XE3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 07-Aug-07 21:46 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
router uptime is 33 minutes
System returned to ROM by reload at 09:43:32 EST Sat May 1 2010
System restarted at 09:44:24 EST Sat May 1 2010
System image file is "flash:c2801-ipbase-mz.124-6.XE3.bin"
Cisco 2801 (revision 6.0) with 97280K/33792K bytes of memory.
Processor board ID FTX1042Z1MU
2 FastEthernet interfaces
1 Cable Modem interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
This also randomly happens:
   entry number 8 : LINEPROTO-5-UPDOWN
    Line protocol on Interface Cable-Modem0/1/0, changed state to down
    timestamp: 3332
   entry number 9 : LINEPROTO-5-UPDOWN
    Line protocol on Interface Cable-Modem0/1/0, changed state to up
    timestamp: 3658
   entry number 10 : LINEPROTO-5-UPDOWN
    timestamp: 174449
   entry number 11 : LINEPROTO-5-UPDOWN
    timestamp: 174744
Here is the interface and BVI:
interface Cable-Modem0/1/0
description HIGH-SPEED WAN INTERFACE
ip dhcp client hostname router
no ip address
ip access-group 101 out
ip nbar protocol-discovery
load-interval 30
traffic-shape group 110 102400 8192 8192 1000
bridge-group 5
interface BVI5
ip address 98.190.xxx.xx 255.255.255.224 secondary
ip nat outside
570
