Calculate bandwidth using SNMP index
marchanamendon
Can you tell me how to calculate bandwidth using snmp index ifInoctets and ifOutOctets.
I can see the output of this indexes using snmpwalk command at different time interval.
But how do I derive the utilization when it reaches 80%.
Archana.
5 Replies 5
Giuseppe Larosa
Hello Archana,
to measure link usage you need to perform the difference between two readings divided for the time interval between the readings and by 8 (bits/byte)
[Ifinoctects (readingN+1) - Ifinoctects (readingN)] /8* (time_readingN+1 -time_readingN)
so now you now the speed and you need to compare to link speed to see when it reaches 80%.
Be aware that being these 32bits counters on high speed links they can wrap:
when the counter reaches 2^32-1 next read will be a lower number then the previous.
There are different ways to deal with this.
One is to use if available the HC versions of counters (64 bits counters)
Another is to read other mibs that track if wrapping has happened
Hope to help
Giuseppe
Hello
Since this parameters are new for me and trying to find the formula,it would be great if you can tell me how do I know what is the bandwidth usage and formula to calculate.
I have collected the MIB value for serial interface of router for 1 min time interval.
At 12.25
IF-MIB::ifInOctets.7 = Counter32: 1427402450
IF-MIB::ifOutOctets.7 = Counter32: 4040163899
At 12.26
IF-MIB::ifInOctets.7 = Counter32: 1427697887
IF-MIB::ifOutOctets.7 = Counter32: 4041427307
ifspeed value for serial interface is this.
IF-MIB::ifSpeed.6 = Gauge32: 1544000
With these value how can I derive the percentage of bandwidth usage for the time period of 1 min.
It would great if you can work it out and explain me.
Archana.
Hello Archana,
providing an example is a good idea.
time= 60 seconds
Diff. Inoctets = 1427697887 - 1427402450 = 295437 octets received in 60 seconds
1 octet = 8 bits
average bit rate = Diff.InOcoctets*8/60 =
39391,6 bps
so the usage is :
39391,6 / 1544000 = 2,55 % usage of BW inbound direction
you can perform a similar calculation for outbound direction
Hope to help
Giuseppe
Hello Giuseppe,
Its really helpful with the way you have explained.
But I have one more doubt,the 2.55% which gives the utilization for an inbound direction.
How do I calculate the total bandwidth utilization for the link?
Archana.
Hello Archana,
from a technical point of view I would keep separated the two directions because it is really normal that usage in the two directions can be quite different.
However, if you want to associate a usage percentage to both direction you can use:
overall_usage= (usage_inbound+usage_outbound)/2
Hope to help
Giuseppe
