calculating bandwidth for internet browsing
We have around 75 users requires internet browsing . How to calculate the bandwidth requirement ?.
Raju
Re: calculating bandwidth for internet browsing
a tricky one! I don't think there would be a strict answer to this. But the right approach is : what kind of traffic is going to the Internet ? Personal internet browsing traffic only, any VPN, extranet ?
But basically a 2xE1 should do.
Hope this helps!
Silver
It would depend on what type of Internet traffic your users are going to do. If just simple browsing then you can do with a T-1(E-1). If you have major users with applications that require major bandwidth, FTP, TFTP, remote restores, Even if they are going to allow streaming video or audio, you may want to consider more bandwidth. For the heavy access you may want to consider a T-3 (E-3).Hope this helps...
Silver
Without knowing any special requirements, I generally use 50Kbps per user as a starting point.
In your case... 50k X 75 = 3.75Mbps
Please rate all helpful posts.
+Brad
165
