Calculation
Need to do calculation based on the below inputs.Pls Suggest me for how much bandwidth link i can go for to upload the documents??
Per Doc : 900kb
Per day : 6GB
2 ACCEPTED SOLUTIONS
Re: Calculation
total data = 6GB = 6 * 2^30 bytes = 6 * 2^30 * 8 bits = 48 * 2^30 bits
total duration = 24 h = 24 * 60 * 60 seconds = 86400 seconds
To download the documents you need at least:
(48 * 2^30 bits)/(86400 seconds) = (almost) 600000 bps = 600 kbps
This the pure bandwidth for the documents. It does not iclude network layers overhead.
Maybe if we add another 100 kbps to make it 700 kbps, you will be ok (just an estimate).
Kind Regards,
M.
Re: Calculation
Hi, You can go for 640,000 bps link to upload your GB, which will take 22 hrs, 22 mins, 10 secs, with out any payload. It has calculated 6GB/day. Thanks Goutam.
Re: Calculation
Hi Nasheer, You don't mention the duration properly. Per day = 24 hrs? Or the total amount of data (6GB) you want to upload ?
Re: Calculation
Per day = 24hrs
regds
Re: Calculation
Kind Regards,
M.
Re: Calculation
Re: Calculation
That means 1 MB link is enough. am i right.
regds
Re: Calculation
Yes, 1 Mbps link is fine.
BTW, when we refer to network speeds we write 1 Mbps (which is 10^6 bps). When we write 1 MB, then 1 Mbyte data is implied (which is 2^20 * 8 bits).
Kind Regards,
M.
Re: Calculation
Hi Nasheer, I'd like to add something with the response of Maria & your post. 1Mbps line, but it is not clear to me… is that Leased line/Internet/MPLS/VSAT? If that 6 Gb data need to cover some security like Crypto then you may need to think before you go for 1 Mbps Link (?). Thanks. Goutam
Re: Calculation
Planning for LL only.
regds
262
