can 2950 switch still be used on current CCNA, CCNP practice?
can 2950 switch still be used on current CCNA, CCNP practice? what about later on in CCIE?
Re: can 2950 switch still be used on current CCNA, CCNP practice
It can be used for CCNA, CCNP, and some CCIE. It's a layer 2 only switch, but very effective for configuring & troubleshooting spanning-tree. STP is a very important topic and is focused on heavily in CCNP and CCIE and this switch would serve well. The biggest difference in CCIE is that they use a layer 3 switch so they can have routable interfaces as well.
HTH and please rate.
Yes, 2950 is a great switch, but you might also want to take a look at the 3560 8 port switch. That's one nifty little bugger.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
except the price ;-)
200
