Community Member
Can a 3640 use a NM-1T3/E3
I need to know if a DS-3 Card (NM-1T3/E3) can work in a Cisco 3640. I have two pages that contradict each other in what platforms work with this card. If it does work with this platform, what is the min IOS? 12.2(11)YT???
The two pages are:
Cisco 2600/3600/3700 Series T3/E3 Network Module: http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
which states that the 3640 is not supported, and
Overview of Cisco NEtwork Modules for Cisco Access Routers: http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/ovrnetm.htm
Which states that all modules listed on page will work in 3640.
Todd
VIP Purple
Re: Can a 3640 use a NM-1T3/E3
Hello Todd,
the information is confusing indeed. I'll send and email to Cisco pre-sales, and see what they say, I will post their response.
GP
Todd,
Even though the second link seems to indicate that the 3640, does support NM1T3/E3, at the bottom of the same link it shows in Table 1-6, that 3640 doesnt support the module. The list of routers that support this seems to be,
Cisco 2650XM
Cisco 2651XM
Cisco 2691
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3660
Cisco 3700 series
Cisco 3800 series
Cisco MWR 1941-DC
There have been questions similar to this in the past in this forum, but I cant seem to locate them via search.
ATM DS3 module NM-1A-T3 seems to be supported on the 3640, but not the NM-1T3/E3.
Community Member
i want to do the same. did you get this confirmed that the NM card does *not* work in a 3640
AFAIK, it doesnt. You will need to use a router like 3700 or 3800.
311
