Can be cef done unequal loadbalance?
Let's say
ip cef
**and**
ip route 0.0.0.0 0.0.0.0 s0 ---> 512k leaseline to ISP1
ip route 0.0.0.0 0.0.0.0 s0 ---> 1M leaseline to ISP2
What is cef can be done in this case?
TIA
Re: Can be cef done unequal loadbalance?
I think you wrongly mentioned the two interfaces as same as s0
If you have two default route via two interfaces s0 and s1 , and both of them having unequal subscibed bandwidth from ISP's , by default will have per destination load balancing .And the 512 K link would be full and the destinations via 512k link will have problems.
You can do a per-packet load balancing , if load-sharing per-packet is mentioned in both the interfaces .
As per your question , Cef cannot do unequal loadbalancing .
Hope it helps
regards
vanesh k
Bronze
ip cef is Cisco express forwarding , it is mainly use for faster switching the packet, It is faster than fast switch and also process switching,
As per your question, IP Cef no play any role in loadbalancing .
-Minu
111
