Community Member
can c4006 use with 4013+?
i want to confirm if switch c4006 can surport engine 4013+.
if there is anyone can make sure of it?
thank you very much?
1 ACCEPTED SOLUTION
Purple
Re: can c4006 use with 4013+?
According to the following document, the Catalyst 4500 Series Supervisor Engine II-Plus is supported on the c4006:
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_qanda_item09186a0080197403.shtml
Hope that helps - pls do remember to rate posts that help.
Paresh
1 REPLY
Purple
Paresh
110
