can CEF be used on a 2821 router's serial interface w/o issue
I am experiencing input queue drops and I noticed that CEF is enabled globally but turned off on the serial1/0 link which is a 45Mb connection to  the Internet.  Is there any reason that CEF cannot be run on a serial link which faces the Internet.
Hello Frank,
I know of no compelling reason to have CEF deactivated on any interface, including a serial link towards internet. How do you know that the CEF is disabled on that interface?
Best reagrds,
Peter
Thanks for responding Peter.  These commands are on the interface in question: no ip route-cache cef and no ip route-cache.
Hello Frank,
Thank you. I see - the CEF is deactivated indeed on the interface.
As I suggested, in normal network operation, there is no reason to deactivate CEF on an interface. You can try reenabling it again.
Best regards,
Peter
401
