04-16-2009 08:21 AM - edited 03-04-2019 04:24 AM
I have a Cisco 1841. I'm curious to know if you can bond T1s together that aren't in the same slot.
Solved! Go to Solution.
04-16-2009 11:18 AM
04-16-2009 08:31 AM
Yes you can.
Hope that helps.
04-16-2009 09:44 AM
thotsaphon provided a GREAT example, do you have any other sample config that I may be able to use? I just like to maybe have a back up plan.
Any assistance is great.
04-16-2009 08:31 AM
Jason,
Do you mean Multilink? Yes,You can
Toshi
04-16-2009 08:48 AM
I have a main site and a remote site that are connected to share bandwidth.
I have a 1841 at the remote site. There is a free slot in the Cisco 1841 at the remote site. I think I can add up to two more T1s in the open slot. Is this correct?
Slot 0: empty
Slot 1: Contains a WIC with two T1 connections.
I have a Cisco 2800 at the main site with multiple slots open.
I am trying to add more bandwidth to the remote site.
Any assistance?
04-16-2009 08:57 AM
Jason,
Cisco1841 has 2 HWIC slots. So you can add another card on slot0. Are you going to implement Multilink?
Toshi
04-16-2009 09:02 AM
yes, PPP Multilink.
Any idea how I could set this up? Will I be able to bond the T1s on both slots.
04-16-2009 09:14 AM
Jason,
You can set it up(both sides). Here is an example.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1/0
framing esf
linecode b8zs
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/1/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
Will I be able to bond the T1s on both slots? Don't worry too much. It can.
HTH,
Toshi
04-16-2009 09:19 AM
thanks!
04-16-2009 10:01 AM
Thanks for your last response, that was QUICK!
By chance would you have another sample (you can leave out the T1 config portion)?
I just always like to have a backup plan?
04-16-2009 11:18 AM
04-16-2009 12:13 PM
Thanks again!
