Can I have LoadBalancing for Two ISP Connections (PPPoE and PPPoA) on Cisco 897va
I have two ISP Connection and I have Cisco router 897va,I want to have loadbalancing for two ISP Connection second connection is PPPoE connection and second is PPPOA(ATM) connection.
It's possible to do this ?
Thank you in advance.
2 ACCEPTED SOLUTIONS
VIP Purple
You can balance per TCP flow
You can balance per TCP flow (the default behaviour with CEF enabled).  Aka one user goes out one pipe and the next user goes out the next pipe.
Make sure you use nat with route-map that matchers the outbound interface, and then you just need two equal cost default routes (one going out each circuit).
VIP Purple
If they both have the same
If they both have the same performance then everyone will have the same experience.
If one is twice as fast, then half the users will have an experience that is twice as fast.  This can then lead to users complaining about intermittent performance problems.
VIP Purple
Two connection should have
Two connection should have the same (download/upload) speed ?
VIP Purple
Thank you very much.
47
