Community Member
Can I run multiple dial pools on an Ethernet interface on my 1721?
I am attempting to configure a 1721 for a remote property that uses DSL with a DSL modem that will go into an ethernet WIC on a 1721. Since I don't know if the ISP uses chap or pap, i was wondering if I could run two dial pools on the ethernet0 interface, with one dialer set up for chap, and the other set up for pap, both with the same IP address. Here is the config I have so far:
interface Ethernet0
no ip address
ip virtual-reassembly
full-duplex
pppoe enable
pppoe-client dial-pool-number 2
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0
description local LAN
ip address 10.*.*.* 255.255.255.0
ip nat inside
speed auto
full-duplex
no cdp enable
interface Dialer0
no ip address
shutdown
interface Dialer1
ip address *.*.*.169 255.255.255.248
ip access-group 102 in
ip mtu 1492
ip inspect FIREWALL out
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ****@pacbell.net
ppp chap password 7 ************************
crypto map rdln_map
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 2
dialer-group 2
ppp authentication pap callin
ppp pap sent-username ****@pacbell.net password 7 ****************************
crypto map rdln_map
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
Will this even work? Or can I only have one dial pool on the ethernet0 interface? If I can have both, it would make things a little easier when I send it to the property.
Any suggestions to tweak up what I have is appreciated... thanks!
1 REPLY
Community Member
Re: Can I run multiple dial pools on an Ethernet interface on my
I think I figured this out... here is what I did:
interface Ethernet0
no ip address
full-duplex
pppoe enable
no cdp enable
ip address *.*.*.254 255.255.255.0
ip nat inside
speed auto
full-duplex
no cdp enable
interface Dialer0
no ip address
shutdown
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
crypto map rdln_map
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
shutdown
dialer pool 2
dialer-group 2
crypto map rdln_map
ip classless
ip nat inside source route-map nonat interface Dialer1 overload
Does this look right?
BTW, does anyone know how to remove the second pppoe-client (pppoe-client dial-pool-number 2) statement from my ethernet0 interface? It doesn't seem to want to go away :)
98
