Can i use Nbar for Cisco 7609 routers to monitor the Layer 4 and above protocols?
hi
I want to monitor the Layer 4 and above protocols on router 7609.
Can i use NBAR for it?
If yes, then how to use it?
If no, then any other alternative way to do it?
regards
abhishek nagar
+447829933033
1 REPLY
Hall of Fame Super Silver
Re: Can i use Nbar for Cisco 7609 routers to monitor the Layer 4
Hello Abhishek,
if your C7609 has a sup720 installed you cannot use NBAR on it.
I would suggest you to consider netflow instead.
Hope to help
Giuseppe
240
