07-31-2006 07:50 AM - edited 03-03-2019 01:30 PM
i use a 3-layer switch to instead the router.
on WAN connetction i use ppp encapsulation protocol.
i'm confused how can use ppp on ethernet?
07-31-2006 08:13 AM
hi...
you can have PPP over Ethernet which is konw as PPPoE
look at this link so you can have clear idea
remember to rate the post, if it helps
regards
Devang
07-31-2006 06:42 PM
i think you misunderstand me !
ppoe is a tech ,which is used on xDSL.
07-31-2006 07:01 PM
There is no need to enable the encapsulation on Ethernet if you are going to replace the router to L3 switch. We normally use PPPoE in DSL but it is really the PPP connection over the Ethernet, just like the PPPoA (PPP over ATM).
You need to enable routing between interfaces in a router / VLANs in a switch.
Please state your question in specific then we can help more. Simple question get simple answer only.
07-31-2006 07:58 PM
hi,
let me speak it again.
i want to use a 3-layer switch to replace the Router,which connects WAN and LAN.
ppp protocol is used on the WAN.
now,the switch only has ethernet port.
i have 2 questions!
Q1.as i know ppp frame is not same as ethernet frame ,switch and remote device can't work correctly!is this right?or use PPoE?
Q2.is it flexible ,what should i configure?
07-31-2006 09:57 PM
i dont think so on ethernet you can have PPP frame...
regrds
Devang
07-31-2006 10:31 PM
topology
before:
.......|(fiber cable to serial cable,running PPP)
.....Router
......LAN
now:
.......|(fiber cable to ethernet cable)
.....switch
......LAN
1.this is large private network ,ppp protocol is runing betwteen center and branch.
2.NAT and VPN are not necessary.
08-01-2006 12:09 AM
Could you please advise why you insist to use PPP ? As I mentioned before, there is no encapsulation PPP under Ethernet. You only need to ensure the remote fibre connection side can support Ethernet then it is fine. It is also not related to NAT or VPN. It is the L1 & L2 issue.
End user is Ethernet LAN, L3 switch use Ethernet, remote user also use Ethernet LAN. WHY require PPP ?
Please ensure the remote side is also changed from serial to Ethernet then it is fine. Otherwise, you still need serial WAN to connect to the router.
Please clarify the technology and the requirement.
Your information still too simple, please provide more if there is question.
08-02-2006 07:37 AM
now i have a carzy idear ,plugging the fiber optic cable into GBIC module,and use ppp on the port.
but i look up the command reference of 3560,there is no "encapsulation ppp" command at all.it means that ppp can't be configured.
it seems that L3 switch can utilize ip routing protocols just on ethernet network only.
Q. i know ,some advanced switch (such as 65XX) are be used as gateway on large compus .
how can they do that ?
do they have WAN ports?
or they don't use WAN protocols at all?
08-01-2006 01:42 AM
hello CHN@.1984
first i think you will go to www.cisco.com/go/fn
and confirm your l3 switch's ios can support pppoe,
second , there're a lots of config case in cco.
08-01-2006 02:08 AM
would you please tell me which device you are using in order to convert the Fiber Cable connectivity to the ethernet cable connectivity... and which type of frame it generating...
regards
Devang
08-01-2006 02:24 AM
(1)DO you want to say that earlier there was some FO to serial converter and now its a FO to ethernet converter.
(2)Are you using same device in both the cases?
JD
08-01-2006 01:20 AM
PPP protocol is generall used for WAN connections.
If you need to do routing between 2 ports of your switch, then you need to configure inter-vlan routing whose example can be viewd in following link.
Instead on "encapsulation ppp" on your serial, you have to define "encapulation dot1q" on a switch.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml.
Hope it helps.
Pls rate all posts.
JD
