Can only ping from Lan, not from router
AndersBramsen
II have a 881g conecting fine with 3G via cel 0
I Can not ping fx 8.8.8.8 or 4.2.2.2 from cli, bur from Lan everyting World fine.. Any helt please?
19 Replies 19
andrew.prince
Level 10
Level 10
You should use an extended ping from the router and use a source interface.
thx
If ny router has 10.10.10.1 Then ping 4.2.2.2 source 10.10.10.1 ?
Yes that is correct.
hmm...still not working on my system, must be something else wrong....
881G#ping 4.2.2.2 source cellular 0 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds: Packet sent with a source address of 95.209.150.20  ..... Success rate is 0 percent (0/5)
881G#ping 4.2.2.2 source 10.10.10.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds: Packet sent with a source address of 10.10.10.1  ..... Success rate is 0 percent (0/5)
STANDARD IP access list 23     10 permit any (9 matches)
Extended IP access list 101
10 permit ip any any
20 permit udp any any
yes - post all relevant config.
881G#sh running-config
Building configuration...
Current configuration : 4296 bytes
! Last configuration change at 00:18:24 UTC Sun Jan 1 2012 by abramsen
version 15.2
no service pad
service password-encryption
hostname 881G
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXX
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2226282873
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2226282873
revocation-check none
rsakeypair TP-self-signed-2226282873
crypto pki certificate chain TP-self-signed-2226282873
certificate self-signed 01
  xxxxxxxxxxfbuibguinhuongu9gy8ft68fbt68fy8fvt8fntgu9hu9cu0fieorcnfgrfrfgu9ferfecf
fcrfgnirf9fnui9rngfru9fghrfurgfrufgrfuer90cfhref
fchiurecfheiun0cfcgrnfucrfghrfgrfhmuief
      quit
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip domain timeout 1
ip domain name it-kon.dk
ip name-server 192.168.0.1
ip name-server 208.67.222.222
ip name-server 8.8.8.8
ip cef
no ipv6 cef
chat-script gsm "" "ATDT*99*1#" TIMEOUT 60 "CONNECT"
license udi pid CISCO881G-K9 sn FCZ1533C590
username xxxxxxxxxx privilege 15 password xxxxxxxxxxxx
controller Cellular 0
ip ssh version 2
no crypto ipsec nat-transparency udp-encapsulation
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description ADSL$ETH-WAN$
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Cellular0
description 3G data
ip address negotiated
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
ppp chap hostname cisco@wwan.ccs
ppp chap password 7 0822455D0A16
ppp ipcp dns request
interface Vlan1
ip address 10.10.10.1 255.255.255.252
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip flow-export destination 192.168.0.56 2055
ip dns view default
domain timeout 1
ip nat inside source static 10.10.10.2 interface Cellular0
ip route 0.0.0.0 0.0.0.0 Cellular0
logging 192.168.0.67
access-list 23 permit any
access-list 101 permit ip any any
access-list 101 permit udp any any
dialer-list 1 protocol ip list 1
snmp-server community xxxxxx RW
snmp-server location Kalundborg, DK
snmp-server contact Anders Bramsen
snmp-server chassis-id 881G
control-plane
line con 0
login local
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
access-class 23 in
privilege level 15
logging synchronous
login local
transport input ssh
ntp update-calendar
ntp server 94.126.0.23 prefer source Cellular0
end
maybe that is the reason i cant ping from router?
Does the line forward all trafic from my Cel 0 directly to my wan interface, While (I am/ the router ) is in the midle ?
Can you do following:
-logging console debug
- no service timestamp debug
- access-list 199 permit icmp any any
-debug ip packet detail 199
then ping 8.8.8.8 rep 1
And post output.
Regards.
Alain
881G#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
881G(config)#logging console debug
881G(config)#no service timestamp debug
881G(config)#access-list 199 permit icmp any any
881G(config)#exit
881G#debug ip packet detail 199
IP packet debugging is on (detailed) for access list 199
881G#ping 8.8.8.8 re
881G#ping 8.8.8.8 repeat 1
Sending 1, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/1)
How are you connected to the router? if it is via a vty line then you haave to do:
- #terminal monitor
-#router(config) logging monitor debug
Then do the test again.
Regards.
Alain.
881G#ping 4.2.2.2 source cellular 0 repeat 1
Sending 1, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
IP: s=95.209.150.20 (local), d=4.2.2.2, len 100, local feature
    ICMP type=8, code=0, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
FIBipv4-packet-proc: route packet from (local) src 95.209.150.20 dst 4.2.2.2
FIBfwd-proc: packet routed by adj to Cellular0 0.0.0.0
FIBipv4-packet-proc: packet routing succeeded
IP: s=95.209.150.20 (local), d=4.2.2.2 (Cellular0), len 100, sending
    ICMP type=8, code=0
IP: s=95.209.150.20 (local), d=4.2.2.2 (Cellular0), len 100, output feature
    ICMP type=8, code=0, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Common Flow Table(26), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, NAT ALG proxy(55), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Post-Ingress-NetFlow(68), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Egress-Netflow(73), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Dialer idle reset(84), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
IP: s=95.209.150.20 (local), d=4.2.2.2 (Cellular0), len 100, sending full packet
    ICMP type=8, code=0.
881G#
but the funny (strange thing) is that if i ping via fa4 witch is adsl, every thing works
that also why i think my ip sla (tracking not is working)...if i bring down CEL0 the it switch fine over to Backuo isp, but shouldent it jump back when primary is up again? Now i manualy have to type ip route 0.0.0.0 0.0.0.0 cel 0 to make it work again
881G#ping 4.2.2.2 source fa4 repeat 1
Packet sent with a source address of 95.166.108.6
Success rate is 100 percent (1/1), round-trip min/avg/max = 364/364/364 ms
881G#
IP: s=95.166.108.6 (local), d=4.2.2.2, len 100, local feature
FIBipv4-packet-proc: route packet from (local) src 95.166.108.6 dst 4.2.2.2
IP: s=95.166.108.6 (local), d=4.2.2.2 (Cellular0), len 100, sending
    ICMP type=8, code=0
    ICMP type=8, code=0
IP: s=4.2.2.2 (Cellular0), d=95.166.108.6, len 100, input feature
    ICMP type=0, code=0, Common Flow Table(4), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Stateful Inspection(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Dialer i/f override(13), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Ingress-NetFlow(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Virtual Fragment Reassembly(25), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Virtual Fragment Reassembly After IPSec Decryption(40), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, NAT Outside(67), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, MCI Check(81), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
FIBipv4-packet-proc: route packet from Cellular0 src 4.2.2.2 dst 95.166.108.6
FIBfwd-proc: Default:95.166.108.6/32 receive entry
FIBipv4-packet-proc: packet routing failed
IP: tableid=0, s=4.2.2.2 (Cellular0), d=95.166.108.6 (FastEthernet4), routed via RIB
IP: s=4.2.2.2 (Cellular0), d=95.166.108.6 (FastEthernet4), len 100, output feature
    ICMP type=0, code=0, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0, Common Flow Table(26), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=0, code=0
881G#, Stateful Inspection(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
IP: s=4.2.2.2 (Cellular0), d=95.166.108.6, len 100, rcvd 4
    ICMP type=0, code=0
IP: s=4.2.2.2 (Cellular0), d=95.166.108.6, len 100, stop process pak for forus packet
    ICMP type=0, code=0
881G#
