07-07-2008 02:27 AM - edited 03-03-2019 10:36 PM
Hi. I read docs about ISG configuration,but can`t fined main commands on my router, like "ip subscriber" "class-map type traffic " "policy-map type service".
Here show ver:
7204#sh ver
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(15)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Jan-08 05:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD2, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(4)XD1, RELEASE SOFTWARE (fc1)
7204 uptime is 14 weeks, 5 days, 23 hours, 31 minutes
System restarted at 13:47:25 MSK Tue Mar 25 2008
System image file is "disk2:/c7200p-adventerprisek9-mz.124-15.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 7204VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 31781376
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
4 slot VXR midplane, Version 2.7
07-07-2008 02:42 AM
I think ISG support is only in 12.2 SR, That is available for the 7200, 12.2(33)SRC1.
Please rate post if it helps!
07-07-2008 03:03 AM
Strange,if I use "Command Lookup Tool" it says that "ip subscriber" command exist in (12.4T),(12.4) and (12.2SR).
Maybe I`m wrong but version 12.2 too old.
07-07-2008 03:09 AM
You can try ad. IP services instead of adv. enterprise for 12.4T.
07-07-2008 03:28 AM
How I know ADV ENTERPRISE include all features from other IOS packages, IP SERV ,ENT SERV.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/index.html
I need to know exact information,because it not so ease to upgrade working router only for testing.
07-07-2008 03:33 AM
Enterprise is for non IP protocols, do you have anything of that ?
If not, you should be using Adv. Ip services that has everything.
07-07-2008 04:03 AM
Ok, I maybe wrong.
07-08-2008 11:05 AM
Hi again
I changed IOS to ADV IPSERVICES but still cant fined any command to configure ISG.
7204(config)#int f0/0.1
7204(config-subif)#ip s?
sap security split-horizon summary-address
7204(config-subif)#
7204#sh ver
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Compiled Wed 30-Apr-08 22:52 by prod_rel_team
7204 uptime is 17 minutes
System returned to ROM by reload at 22:44:11 MSK Tue Jul 8 2008
System restarted at 22:45:47 MSK Tue Jul 8 2008
System image file is "disk2:/c7200p-advipservicesk9-mz.124-15.T5.bin"
Last reload reason: Reload Command
Last reset from power-on
