Can't get interfaces up together
jfrancois
I have a 2620 and a 2610 router. Hardware is not the issue because when I did a hardware reset indivuidually the interfaces came up fine. However, once I used a crossover cable, I can't get them to be up together. I am so mad because the process is so simple and it's kicking my behind. Any suggestion will be appreciated, family
-JMF
16 Replies 16
Richard Burts
JMF
Is there possibly any problem with the cross over cable? Is there possibly a speed mismatch between the interfaces?
It would be helpful if you would post the configuration of both interfaces and post the output of show interface for each interface.
Rick
Rick
Thank you for getting back to me so quick. Ihave tons of Crossover cable - I changed them over and Over - didn't set the speed.
Here is a copy of both configs:
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/0
ip address 10.5.5.1 255.255.255.252
no ip directed-broadcast
interface Serial0/0
ip address 192.168.65.1 255.255.255.252
no ip mroute-cache
no fair-queue
service-module t1 clock source internal
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
login
end
Router#
NJ#sh run
version 12.0
hostname NJ
no logging buffered
no logging console
no logging monitor
enable secret xxx
enable password xxx
ip subnet-zero
no ip domain-lookup
interface Ethernet0/0
no ip address
shutdown
interface Ethernet0/0.1
interface Serial0/0
ip address 192.168.65.2 255.255.255.252
router rip
network 10.0.0.0
network 172.20.0.0
ip classless
line con 0
line aux 0
line vty 0 4
password xxx
no login
no scheduler allocate
end
NJ#
from a config level it looks ok. Going Serial to Serial with a crossover. Something you maybe already have done.
sh ip int bri
Just want to know what each router says here?
Also you may want to specify clock source external on the other router.
Try a shut no shut on the serial interfaces.
Here Are couple of things that I have noticed:
1. Your interface on the NJ router is in " Shutdown" state. Did you try enabling it by using " no shut " under the interface config mode.
2. Your NJ router has an ethernet port and the other router has a Fastethernet port. Typically the auto-negotiation should work and both the sides will fall back on 10 MB/half-duplex. If its a problem with auto-negoatiation then sometimes the link desnot comeup fine. I would suggest you to try hard-coding the speed and duplex on both the sides.
Let us know your findings on this.
-amit singh
Guys, I have assumed that the original poster is trying to connect it via the ethernet ports on both the routers.
Please clarify this that whether the routers are connected using the serial or ethernet links.
-amit singh
I believe it is serial based on the /30 applied. But you are right we need to know for sure.
I am trying serial to Serial - Sorry about that.
-JMF
what do you see in your sho ip int bri
also do a sho interface
post both so we can get an understanding of what is being shown.
Alright guys;
Here it is
Here I just show you the hardware loopback test. The result tells me that the hardware is fine.
Router#sh ip int brief
FastEthernet0/0 10.5.5.1 YES NVRAM up down
Serial0/0 192.168.65.1 YES NVRAM up up
NJ#sh ip int brief
Ethernet0/0 unassigned YES unset administratively down down
Ethernet0/0.1 unassigned YES unset administratively down down
Serial0/0 192.168.65.2 YES NVRAM up up
NJ#
One of you guys request a "sh Int" for both routers. Here they are
NJ#sh int s0/0
Serial0/0 is up, line protocol is up (looped)
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 192.168.65.2/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:01, output 00:00:01, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
14 packets input, 1621 bytes, 0 no buffer
Received 14 broadcasts, 0 runts, 0 giants, 0 throttles
1678 input errors, 722 CRC, 932 frame, 0 overrun, 0 ignored, 24 abort
15 packets output, 1645 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
3 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
NJ#
Router#sh int s0/0
Serial0/0 is down, line protocol is down
Internet address is 192.168.65.1/30
reliablility 255/255, txload 1/255, rxload 1/255
Last input 00:02:38, output 00:02:38, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
2 packets input, 363 bytes, 0 no buffer
Received 2 broadcasts, 0 runts, 1 giants, 0 throttles
1713 input errors, 466 CRC, 1195 frame, 0 overrun, 0 ignored, 51 abort
2 packets output, 363 bytes, 0 underruns
0 output errors, 0 collisions, 27 interface resets
2 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
Router#
I made couples modification but NO luck!!
NJ#sh run int s0/0
interface Serial0/0
end
NJ#
Router#sh run int s0/0
interface Serial0/0
no ip mroute-cache
no fair-queue
end
Thank you guys...You are awesome!
-JMF
Router#
I see that you have under both interfaces the command "service-module t1 clock source internal". For back-to-back configurations one of the interfaces must have "service-module t1 clock source line".
Kind Regards,
M.
JMF
It is significant that you are attempting to connect serial to serial. That leads me back to questions about the crossover cable. Would I be correct in assuming that you are using a normal Ethernet crossover cable? If so that is the problem. A crossover cable for serial is significantly different from a crossover for Ethernet. Is this a serial crossover or an Ethernet crossover?
Rick
Rick
Ah...good call Rick
Yes a serial to serial is pins
1 - 3
2 - 5
3 - 1
5 - 2
This is the pinout
I am sure that I am using an ethernet crossover cable.
either cut one end and crimp a new end on or find someone who can either make a T-1 cable or buy one.
Thanks again Rick for pointing that out.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
