can't pint fas0 interface from ser0 on 1721 - clearly a routing issue?
i can't ping the fas0 from the se0 on the same machine...i can get from the 3/0:0 on the core router to the se0 on the 1721 i'm trying to configure, however, i can't seem to establish a route that gets through. see below:
****new 1721
version 12.3
service password-encryption
hostname xxxxxx
boot-start-marker
boot-end-marker
enable secret xxxxxxx
enable password xxxxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip name-server xxxxxxx
no ip cef
interface FastEthernet0
ip address xxxxxxxxxx.33 255.255.255.224
speed 100
full-duplex
ip address 10.1.5.1 255.255.255.0
encapsulation ppp
no ip route-cache
random-detect
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.5.2
ip route xxxxxxxxxxxx.97 255.255.255.255 10.1.5.2
no ip http server
****connecting to core 7204
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname xxxxxx
aaa new-model
aaa authentication login default local
enable secret xxx
username xxxxxx password xxxxxxxx
ip subnet-zero
ip name-server xxx
ip name-server xxx
ip name-server xxx
ip name-server xxx
ip cef
call rsvp-sync
controller T1 3/0
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 3/1
framing esf
linecode b8zs
controller T1 3/2
framing esf
linecode b8zs
controller T1 3/3
framing esf
linecode b8zs
controller T3 4/0
interface FastEthernet0/0
ip address xxxxxxxxxxx.65 255.255.255.224 secondary
ip address xxxxxxxxxx.97 255.255.255.224
no ip route-cache
no ip mroute-cache
duplex full
interface FastEthernet1/0
ip address xxxxxxxxx.129 255.255.255.224
duplex full
interface Serial2/0
ip address 10.1.2.2 255.255.255.0
framing m13
cablelength 10
dsu bandwidth 44210
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
interface Serial3/0:0
ip address 10.1.5.2 255.255.255.0
encapsulation ppp
random-detect
ip classless
ip route 0.0.0.0 0.0.0.0 xxxxxxxxx.1
ip route 0.0.0.0 0.0.0.0 10.1.2.1
ip route xxxxxxxx.1 255.255.255.255 10.1.2.1
ip route xxxxxxxx.33 255.255.255.255 10.1.5.1
no ip http server
snmp-server community public RO
snmp-server enable traps tty
dial-peer cor custom
see any probs? thanks for looking.
Purple
Re: can't pint fas0 interface from ser0 on 1721 - clearly a rout
Just to understand your problem better, let me clarify what you are trying to do: when you ping xxxxxxxxxx.33 from the 7204 it does not work, right ?
Would you be able to do: 'sh ip ro xxxxxxxxxx.33' on your 7204 and check that it does indeed point to the serial interface ?
Paresh
Hi Paresh,
Correct. The problem appears even worse. From the ser0 interface on the 1721 (telnet via 10.1.5.1), i can't ping Fas0 interface which i assigned xxxxxxxxx.33.
here is the info you asked for on the 7204:
Router>sh ip ro xxxxxxxxxxx.33
Routing entry for xxxxxxxxxxx.33/32
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 10.1.5.1
Route metric is 0, traffic share count is 1
don't know if this helps, but i ran the same commands in the 1721 and got the following:
Router>telnet 10.1.5.1
Trying 10.1.5.1......
newport>sh ip route xxxxxxxxx.33
% Subnet not in table
newport>sh ip route 10.1.5.1
Routing entry for 10.1.5.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
* directly connected, via Serial0
also, noticed on a sh ip route command does not show an an ip address directly connected via Fas0. might that be related to this problem?
thanks
Purple
The fact that a route for a directly connected interface does not appear in a routing table is, of course, a major concern. And that is really why you can't ping it from your other router.
Can you do a 'sh int fast0' and see that the interface is actually up ? Also, verify that the Ip address reported by this command mathes what you are trying to ping ...
Paresh
Hi Paresh,
Looks like it's up and I verified the ip address matches the one i'm trying to ping. Also, there is no device plugged into the fast0 right now, which is why line protocol is down...but that shouldn't affect not being able to ping the fast0 interface from the ser0 interface right?
Here is the info:
newport>sh int fast0
FastEthernet0 is up, line protocol is down
Hardware is PQUICC_FEC, address is 000f.8fef.f701 (bia 000f.8fef.f701)
Internet address is xxxxxxxxx.33/27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 1d17h, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
849 packets input, 68758 bytes
Received 327 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
15462 packets output, 931623 bytes, 0 underruns
17 output errors, 0 collisions, 4 interface resets
17 lost carrier, 0 no carrier
David
Paresh,
I can ping the Fas0 port now...i have one more issue but i think i can solve it. Thanks for your thoughts.
David
Purple
Hi David,
You cannot ping addresses of down interfaces. That is true across all interface types.
Hope that helps,
paresh
152
