Can't see FXS card
w_basheer
Hi;
I have 2811 router with serial & FXS cards.
I can't find the FXS card??
R1#sh ve
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Feb-06 16:37 by ccai
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T6, R)
R1 uptime is 9 minutes
System returned to ROM by reload at 21:19:18 UTC Thu Apr 12 2007
System image file is "flash:c2800nm-adventerprisek9_ivs-mz.124-4.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1032A2CP
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
9 Replies 9
paolo bevilacqua
Show diag please ?
hi;
when i do show diag .. the i get the following :S
R1#show diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.2.0
EEPROM contents at hardware discovery:
PCB Serial Number : FOC10303E35
Hardware Revision : 3.0
Top Assy. Part Number : 800-26920-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20060801
Chassis Serial Number : FTX1032A2CP
Chassis MAC Address : 0019.0685.73e0
MAC Address block size : 24
CLEI Code : COM7C00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-04
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 30 33 30 33 45 33 35 40
0x10: 03 E7 41 03 00 C0 46 03 20 00 69 28 03 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 1A 81 C2 8B 46 54 58 31 30 33 32
0x40: 41 32 43 50 C3 06 00 19 06 85 73 E0 43 00 18 C6
0x50: 8A 43 4F 4D 37 43 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 04 89 56 30 34 00 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision G0
Serial number 28646321 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 01 B5 1B B1 50 0C 6D 01 00 00 00 00
0x30: 80 00 00 00 02 06 24 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
FXS Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware revision 1.1 Board revision B0
Serial number 29954157 Part number 800-02493-04
FRU Part Number VIC-2FXS=
Connector type Wan Module
0x20: 01 0E 01 01 01 C9 10 6D 50 09 BD 04 00 00 00 00
0x30: 58 00 00 00 03 03 04 01 FF FF FF FF FF FF FF FF
Hi Waleed
I think your ISR router doesn't support the VIC-2FXS card which you are using.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080094fac.shtml
L.Thot
Dear;
thanks for the prompt
but do you have idea what sgould i do?
Sure thing..
c2800nm-ipvoicek9-mz.124-13a.bin
That's the latest LD version for IP VOICE.
Please let me know if that helps your FXS card being not recognized.
I have experienced this exact same problem and had to download a version of IOS that supported voice. Login to CCO and utilize the Software Advisor.
Ok; thanks i will but i tried the following images:
c2800nm-ipvoicek9-mz.124-12a.bin
do you have exact image name?
thanks
I missed this one, but thotsaphon was totally correct... You have a VIC-2FXS card but you if you want that functionality on a 2811 you need to install a VIC2-2FXS card.
Make sure to credit thotsaphon with the correct answer and make sure to check out his link. If you scroll down to find the 2811 in the table you will see what is and what is not supported.
Thanks i got it.
i loosed 4X cards :D
