11-21-2013 05:08 AM - edited 03-04-2019 09:38 PM
I can't figure out why the wireless interface is not comming up, or the SSID can't be found.
The current config:
THE CONNECTION TO THE SWITCH
interface FastEthernet4
description secondary-TO_SW
no ip address
no ip route-cache
duplex auto
speed 100
no cdp enable
interface FastEthernet4.109
encapsulation dot1Q 109
ip address 192.168.71.4 255.255.255.0
no ip route-cache
THE INTERFACE
R#sh run int dot11Radio 0
Building configuration...
Current configuration : 299 bytes
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 10 mode ciphers tkip
broadcast-key vlan 10 change 45
ssid MY SSID
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
end
no ip address
no ip route-cache
ssid MY SSID
station-role root
rts threshold 2312
What am I missing?
Thank you
11-21-2013 02:03 PM
Something doesn't look right with this:
bridge irb
interface Vlan109 <----- The VLAN used on the F4 with the internet switch
no ip address
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
no ip address
bridge 1 route ip
If you have 10.10.1.1 on bvi1, you now have vlan 109 associated to that bvi. I'm not sure this will work, but try this:
int bvi1
no ip address
int bvi10
ip address 10.10.1.1 255.255.255.0
bridge 10 route ip
HTH,
John
*** Please rate all useful posts ***
11-21-2013 02:17 PM
done that, still keeps stuck on the "obtaining IP address"
11-21-2013 02:20 PM
I looked at your last full config, but I don't see a dhcp pool....did you create it?
HTH,
John
11-21-2013 02:06 PM
For better understand, here's my full config:
R#sh run
Current configuration : 2350 bytes
version 12.4
no service pad
hostname R
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 **********************
no aaa new-model
dot11 syslog
dot11 ssid MY_SSID
vlan 10
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 **************
ip source-route
no ip routing
no ip cef
no ip domain lookup
ip domain name domain.ar
ip name-server ***.***.***.***
ip name-server 8.8.8.8
no ipv6 cef
username user privilege 15 password 0 pwd
archive
log config
hidekeys
bridge irb
interface FastEthernet0
shutdown
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
no ip address
no ip route-cache
duplex auto
speed 100
no cdp enable
no ip route-cache
no ip address
no ip route-cache
ssid MY_SSID
station-role root
rts threshold 2312
interface Dot11Radio0.10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan109
no ip address
no ip route-cache
bridge-group 1
interface Dialer0
no ip address
shutdown
interface BVI1
ip default-gateway 192.168.71.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
scheduler max-task-time 5000
end
thanks a bunch so far
11-21-2013 09:37 PM
hi,
can you try these commands:
ip dhcp excluded-address 192.168.1.1
ip dhcp pool VLAN_10
network 192.168.1.0 /24
default-router 192.168.1.1
dns-server
dot11 ssid MY_SSID
guest-mode
encryption mode cipher aes-ccm tkip
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface bvi10
int vlan 10
bridge-group 10
interface dot11radio0
ssid MY_SSID
vlan 10
authentication open
wpa-psk ascii
bridge-group 10
11-22-2013 04:30 AM
Hi John,
on part:
dot11 ssid MY_SSID
guest-mode
encryption mode cipher aes-ccm tkip <------------------ It's not accepting this command
interface bvi10
ip address 192.168.1.1 255.255.255.0 <-----------------overlaps with BVI1
ssid MY_SSID
vlan 10
authentication open <---------------------------------Command not accepted
wpa-psk ascii
bridge-group 10
