Webcast-Catalyst9k
Can the 827 act as an Ethernet Router?
My example:
I have a SHDSL connection and have a Cisco 828 configured to bridge and behind that I have an ethernet router - something like a Netscreen Firewall which holds the WAN IP address.
What I want to do is replace the Netscreen firewall with a Cisco 827 so the 827 just becomes an ethernet router.
Cisco 828 (set to bridge) <- Cisco 827 (ethernet router) <- LAN
If this is possible, does anyone have any config for the 827 to act as an ethernet router in this fashion?
Thanks.
Re: Can the 827 act as an Ethernet Router?
Are you talking about Cisc 827V ?? it contains 4 Analog Telephone ports and a 10Mbps ethernet port.
do revert back if thts the provisioning in your scenario too ,if that happens to be there in place at your side i dont think you will be able to interface (connect) or make your router as a ethernet router to connect the lan to other Cisc 828 router..
regds
If I understand correctly you set up. You will need a router with 2 Ethernet ports. 1 connect to the bridge and 1 to the LAN.
C827 has only 1 Ethernet port.
cisand
106
