Community Member
Can WIC and HWIC coexist?
I have a 2811 with c2800-advsecurityk9-m, version 12.4 (11)xw, which i recently installed.
up to recently, i only had a single wic (adsl over pots) installed that i used for my internet.
i decided to add a second line to our office, and so ordered an hwic (adsl over pots). however, the router see's only one of them at a time, whichever one is installed in 0/0.
Any ideas?
Hall of Fame Super Gold
Re: Can WIC and HWIC coexist?
which exact version of 12.4(11)XW ? can you upgrade to XW4 and try again?
Also please collect output of show ver and show diag, post it here.
Community Member
alrighty,
ive attached my show ver, and show diag...
i can upgrade ios, but will it work??
You should upgrade anyway because very first XW has many bugs and has been deferred.
I can't tell if it will work. The wic card is not recognized when coexisting with hwic. If after upgrade problem still exist, I suggest that you contact the TAC for assistance.
Community Member
What ios would you recommend??
i tried 12.4(15)...and a few others..nothing...
You may be running into some sort of incompatibility, no matter the IOS used, and the last word on that is to cisco.
I think two HWICs should work.
Community Member
i tried to wics, and they didnt work...
You definitely need to confirm with cisco on this issue. If the producet are still new you are entitled to support even in lack of a contract, mention this to the dispatcher and they should open a case for you.
127
