Can you help? Two dialer interfaces with IP SLA for default route failover - issues
Matthew burnley
I have an issue with a Cisco 2821, it has an ADSL2+ HWIC  whose ATM interfaces is linked to dialer 1 and a Gi0/1 interface with a pppoe client which is linked to dialer 2.  Both dialer interfaces are up with their respective IP addresses.  If the ADSL on dialer 1 fails i want the IP SLA to kick and and replace the default route for dialer 1 with one for dialer 2.
This config works if you manually shut down the dialer 1 interface, it injects the default route for dialer 2 and then when you unshut the interface, the default route for dialer 1 comes back.  The problem i have is if you take out the cable for the ATM interface and take it down, it does not take the route out the routing table and the default route for dialer2,  which works if you just shut down dialer 1 does not appear.
whats the difference between shutting down dialer1 and it fails over the default route and taking the cable out then it does not?
Here is my config, i'm sure its something simple i'm doing wrong, can anyone help???
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$qOOJ$HV5AH6US/YZMuCGPYp3pP.
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1
ip dhcp pool pool1
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 188.92.232.50 188.92.232.100
no ip domain lookup
no ipv6 cef
voice-card 0
 no dspfarm
archive
 log config
  hidekeys
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
 description Gi0/30 Local LAN
 ip address 192.168.0.1 255.255.255.0
 ip verify unicast reverse-path
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly
 no ip mroute-cache
 duplex auto
 speed auto
 snmp trap ip verify drop-rate
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 2
interface ATM0/2/0
 description ATM0_DSL
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 logging event atm pvc state
 logging event subif-link-status
 no atm ilmi-keepalive
 dsl operating-mode auto
 dsl enable-training-log
 pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer1
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 keepalive 1 3
 no cdp enable
 ppp lcp predictive
 ppp authentication pap chap callin
 ppp chap hostname ********@ccsleeds.net
 ppp chap password 0 ********
 ppp pap sent-username *******@ccsleeds.net password 0 ********
interface Dialer2
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 encapsulation ppp
 dialer pool 2
 keepalive 1 3
 no cdp enable
 ppp lcp predictive
 ppp chap hostname **********@adsllogin.co.uk
 ppp chap password 0 *********
 ppp pap sent-username *********@adsllogin.co.uk password 0 ***********
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 10
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip sla 1
icmp-echo 8.8.8.8 source-interface di1
timeout 1000
threshold 100
frequency 3
ip sla schedule 1 life forever start-time now
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 password test
 login
scheduler allocate 20000 1000
end
Dragan Ilic
Level 4
Level 4
First you only need one of these:
Not both - just leave one with track 1 at the end.
Second I suggest you use EEM with this config because when your config track 1 goes "down" and replace default route with dialer 2 track 1 is again up because 8.8.8.8 is reachable. In EEM you can go with shutting down interface.
Third don't use google dns for reachability - i use that once and they banned my ip for ICMP traffic :)
BR,
Dragan
HTH,
Dragan
Dragan Ilic
Level 4
Level 4
BR,
Dragan
HTH,
Dragan
Hi Dragan.
I found i needed both as the first one was to actually get out to google to be able to track the ip sla in the first place.  I got to the bottom of this in the end, i needed a static route to point to google behind the dialer 1 interface so it could run the ip sla test even if the second dialer default route was active.
With EEM can this be used to shut and unshut interfaces incase of a failiure?  For example if a leased line went down and stopped responding to ping, could i sue EEM to unshut the dialer interface and ip lsa to inject a default route for it?
Could you provide some config for how EEM could shut and unshut the interfaces?
Matt
Sure that EEM can shut/unshut interface...you have "event track" in EEM for monitoring track events...for example:
event manager applet test
event track 1 state down
action 1.0 command "enable"
action 1.1 command "conf t"
action 1.2 command "interfac dialer 1"
action 1.3 command "shut"
action 1.4 syslog "Dialer 1 down!!!"
action 1.5 end
This would be an example from head :)
You would need another EEM similar to this one for unshutting interface with "event track 1 state up" for bringing interface up again.
Again as I said you would need to test this before putting in production and you would maybe need to tweak this a little bit acording to your needs...
BR,
Dragan
HTH,
Dragan
you need to remove one entry, it will work
no ip route 0.0.0.0 0.0.0.0 Dialer1
kazim
