Can you help with sla please.
It's example:
ip sla monitor 30
type echo protocol ipIcmpEcho 172.16.101.66 source-ipaddr 172.16.101.65
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 30 life forever start-time now
track 30 rtr 30
ip route 77.87.16.98 255.255.255.25 5 172.16.100.228 track 30
but i'd like to add route "ip route 77.87.16.98 255.255.255.255 172.16.100.228" when ping from 172.16.101.65 to 172.16.101.66 not working.
Is it possible.
Can you help me please.
Everyone's tags (3)
Hall of Fame Super Silver
Hello Villi1977,
the secondary static route has to be added as floating ( with an higher AD)  for example
ip route 77.87.16.98 255.255.255.255 172.16.100.228 220
means administrative distance AD 220, in this way until the primary route is considered valid the secondary route is not used
When the IP SLA fails the primary route is removed and the secondary route is used
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Hope to help
Giuseppe
Thank you i done next solution.
ip sla monitor 30
timeout 1000
threshold 2
frequency 3
track 30 rtr 30 reachability
ip route 77.87.16.98 255.255.255.255 GigabitEthernet0/1.3712 track 30
ip route 77.87.16.98 255.255.255.255 172.16.100.228 200
interface GigabitEthernet0/1.3712
encapsulation dot1Q 3712
ip address 172.16.101.65 255.255.255.252 secondary
ip address 77.87.16.97 255.255.255.252
Hello Villi1977,
your static routes have a destination = to the primary IP address on the other side of gi0/1.3712 and your IP SLA is based on the secondary IP addresses.
What are you trying to achieve with this setup? It is a correct configuration at syntax level but it is not totally clear what is the objective.
Hope to help
Giuseppe
190
